Hey guys,
I have an Volkswagen Golf IV GTI 1.8T 2002. It originally had 150bhp, right now it's at around 400bhp, it's heavily modified (big turbo, injectors, manifold, IC, exhaust etc). I have had this car for a long time and I drove it on big turbo for around 20k miles.
Just a few months ago I had engine completely rebuilt. I changed rods, pistons, new rings. Engine head had also been swapped to one with bigger exhaust ports. I did compression test a few weeks ago and it had perfect compression (190 psi on all 4 cylinders) and I want to keep it this way.
So far I used Valvoline SynPower 5W-40 or 0W-40, depending on what my local stores had but always SynPower. Here is the list of oils I CAN get locally without problems and list of oils I am considering. I need you to tell me if these are any better than Valvoline Synpower for my engine.
Liqui Moly High Tech (1307-5L) 5W-40 (full synthetic)
TOTAL Quartz 9000 5W-40
TOTAL Quartz 9000 ENERGY 5W-40
Almost ANY Castrol oil
Almost ANY Mobil 1 oil
ARAL Super Tronic 0W-40 (i use this in my MB E320 CDI, it's 229.51 approved)
ROWE HIGHTEC SYNTH RS 0W-40
Thanks for your help you guys. I really don't know much about oils and would appreciate any input you might have. Thank you!
