My Daughter's Grand Am has been leaking transmission fluid from the cooler lines. I was going to just splice in some rubber line, but decided to get all new lines from the wreckers (for $25) I have been able to loosen all fitting except the lower fitting that goes into the rad. I have pulled as hard as I could and even broke my wrench pulling on it. I then cut the line to slip my 5/8 one to get the best grip. No room to use heat as the rad is plastic.
Any ideas how to get the fitting out? I am now looking at going back to the splice idea, but I would really like to replace these lines.
