On the opposite end of the spectrum, many Honda Metropolitan and Ruckus owners are commonly getting 30,000 miles plus out of the 49cc engines on these little scooters before the engine is touched. That's a single-cylinder liquid cooled engine turning 5k rpms or more average (CVT) on a fairly continous basis.
Now 30,000 miles doesn't sound like much, but considering the engine is only 49cc's - a single cylinder - averaging 30-35 mph (40-45 max), that's quite an accomplishment. That's not the upper limit on these either, a probable set of crank bearings and good to go again for another - who knows. Keep in mind these do not have an oil filter either - just a gravel screen.
I've even seen chonda scooters (chinese 139qmb clone) with 20,000 miles on them (not every day mind you). Now that's using a time-proven design with lesser-quality/lower grade parts. Same gravel screen filtration, but 95% of the chonda scooters are air-cooled at that.
Simply amazing when you consider all of the variables involved.
Rob
