I have a few GMS to tranny flush, at 19 bucks and change a case of the Sam's Club Certified Dexron®-III/Mercon® is tempting, Is this stuff any good? any Ideas.
Thanks in advance.
There is no such thing as certified Dexron-III nor Mercon ATF.
GM stopped licensing Dexron-III a couple of years ago when they brought out Dexron-VI. To be perfectly clear, the same stuff as Dexron-III(H) is licensed by GM under the label of Allison TES-389.
Ford stopped licensing Mercon also a couple of years ago. They now recommend the current version of MerconV for all Ford transmissions that originally called for Mercon or MerconV.
I saw Havoline D/M3 ATF for $1.10/qt at our local Sams, about $13/case of 12 qts. Hard to beat that for a quality DexIII/Mercon. Several have reported excellent result from Chevron DM3 ATF, and this is probably the same stuff with a Havoline label.
