I have a new-for-me 1995 Mercedes Benz E320 wagon, without a fully-detailed service history from the previous owner. 140Kmiles on the M104 engine, which I believe is not a roller-cam engine (making ZDDP/other-EP additive level important, based on my reading here).
The owner's manual calls for API SH/SJ (which I realize is obsolete), and looking at the chart in the manual shows a 5W-40 weight as a wide-temperature-range choice.
It seemed like the only means to accomplish the 5W-40 at my local WalMart are: Mobil 1 TDT, or Shell Rotella T6. Both HDEO oils that say they are also suitable for gasoline engine use. Anyone care to offer an opinion on using either of these in my wagon?
I've found the "Mobil 1 Engine Oils" PDF dated 4/7/2009, and the TDT seems to have higher zinc and phosphorus levels than the "high mileage" products, even a bit better than the 0W-40. Is there any later documentation from Exxon-Mobil?
Can anybody point me at an equivalent document covering the Rotella T6?
Thanks for any pointers and advice!
