I want to change all the fluids on a '04 Lexus RX330.
I know the rear differential has a drain plug and uses GL-5 75w-90 gear oil, the transfer case should also have a drain plug and uses the same fluid.
Does the front differential have a separate drain plug and uses 75w-90 gear oil or does it share the fluid with the transmission as many Pilot's and MDX's do?
I wanted to convert the transmission over to Amsoil ATF and the rest to Amsoil Severe Gear 75w-90.
