wolf's head universal synthetic transmission fluid
michigan
Has anybody used this.I want to try it in my 03 taurus. It is about $5.60 a quart at my local napa. Are they manufacturer approved for all these applications or just claiming to exceed the specifications.
http://www.wolfshead.com/specsheets/universalsynthetic.pdf
TYPICAL INSPECTION DATA
• ATF Type A-Suffi x A
• Aisin Warner M315 Type A-1, AW-1, 3309
• Acura ATF-Z1 (VTM-4)
• Allison C-3, C-4, TES-295, TES-389
• Alfa Romeo (all vehicles)
• American Motors ATF+3(MS7176-E), ATF+4(MS 9602)
• Audi ZF, 5HP19FL, 5HP24A, LT71141, TL 52162
• Audi G-052-025-A2, G-052-162-A1, A2, G-052-182-A2
• Audi G-055-025-A2, G-052-180-A2(CVT)
• BMW 83 22 9 400 (272,275)
• BMW 83 22 9 407 (765,807,858,859)
• BMW 83 22 0 397 (114)
• BMW ZF, 5HP (18FL,19FL, 24A, 30), LA2634
• BMW ETL-7045E, ETL-8072B, N402, LT71141
• Caterpillar Power Shift TO-2
• Chrysler ATF+3(MS7176-E), ATF+4 (MS 9602)
• Chrysler CVTF +4
• CVT - Continuously Variable Transmissions
• Daewoo LT 71141
• Daihatsu ALUMIX MULTI, Daihatsu ECO CVT
• Esso LT 71141, EZL 799 (CVT)
• Fiat (all vehicles), Type TIV
• Ford Mercon®, Mercon® V (XP-5-QM)
• Mercon® SP(XT-6-QSP), Mercon® LV(XT-10-QLV)
• Ford WSS-M2C-33-A/B/C/D/F/G
• Ford WSS-M2C-138-CJ, 166-H, 185-A, 195-A, 202-B
• Ford WSS-M2C-910-A, 922-A1, 924-A (XT-8-QAW)
• Ford Type-F *(certain applications after 1977)
• Ford CVT WSS M2C933-A (XT-7QCFT)
• Fuji ECVT, ICVT
• GM Dexron®, II, II-E, III, III-G, III-H
• GM Dexron® VI, GM DEX-CVT
• GM 12378515 (Transynd® applications)
• GM Transfer case 12378396, 12378508
• Honda ATF-Z1 (VTM-4)
• Honda Multimatic CVT
• Hyundai SP-II, SP- III, NWS-9638
• Idemitsu K17, Jatco 3100 PL085
• Infi nity, Matic–D, Matic-J, Matic-K
• Isuzu Besco ATF –II, ATF-III
• Jaguar ZF 5HP24, LT71141, JLM20238
• Jaguar M1375.4, ATF 3403 M115
• JASO M315 Type 1-A
• Jeep (ATF+3, ATF+4)
• JWS 3309
• Kia SP-II, SP-III
• Lexus Type T, T-II, T-III, T-IV, WS
• MAN 339A,F, V1, V2, Z1, Z2, Z3
• Mazda ATF-M III, ATF M-3, ATF-MV
• Mazda V (XT-9-QMM5)
• Mercedes Benz ZF 4HP20,236.1, 236.2, 236.3(PSF)
• Mercedes Benz 236.5(C-4), 236.6, 236.7, 236.8,236.81
• Mercedes Benz 236.9, 236.10, 236.12 (NAG1,NAG2)
• Mercedes Benz 236.20(CVT)
• Mini Cooper T-IV, CVT EZL 799 (83 22 0 136 376)
• Mitsubishi Diamond SP II, SP III, Dia Queen J2
• Mitsubishi Invecs-III CVT, Sportsmode 6 CVT
• Nissan, Matic–D, Matic-J, Matic-K, Matic-S
• Nissan CVT NS-1, NS-2
• Opel 19 40 700, 19 40 707, 19 40 767
• Peugeot ZF 4HP20
• Porsche ZF 5HP19FL, ATF 3403-M115, T-IV
• Renault (all vehicles), Renk-Doromat
• SAAB 3309, 93 165 146, 93 165 147
• Saturn (see GM)
• Scion (all vehicles)
• Shell 3403, 3353, LA 2634, M-1375.4
• Subaru ATF, AT-HP
• Suzuki ATF 3309, 3317, Suzuki CVT Oil
• Texaco ETL-7045E, ETL-8072B, N402
• Toyota Type T-II, T-III, T-IV,
• Toyota WS
• Toyota Super CVT fl uid TC
• Vickers M-2950-S, I-286-S
• Voith G607 (55.6335.XX) G1363 (55.6336.XX)
• Voith Turbo, ZF, Ecomat
• Voith ZF TE-ML 02F, 03D, 04D, 05L, 09, 11B
• Voith ZF TE-ML 14 A,B,C , 16L, 17C
• Volvo 97340, 97341, 1161521, 1161540, T-IV
• VW ZF, 5HP19FL, 5HP24A, LT71141, TL 52162
• VW G-052-025-A2, G-052-162-A1, A2, G-052-182-A2
• VW G-055-025-A2, G-052-990-A2
• VW G-052-180-A2(CVT)
PERFORMANCE APPLICATION CHART
*The chart below lists suitable for use applications
SAE
0W-20
35.0 190 6.50 29.0 180 API
Gravity
Flash
Point Co
Viscosity, cSt
@100C
Viscosity, cSt
@40C VI
Brooksfield
Viscosity, cP.
Pour
Point, Co
found the amalie version for $5/quart shipped. I found out from the msds that it is a group 3 oil with 14% pao.
Amalie Universal Synthetic ATF
__________________________________________________________________________
1. CHEMICAL PRODUCT AND COMPANY IDENTIFICATION
Material Identity
Product Name: Universal Synthetic ATF
Company Telephone Numbers
Amalie Oil Company Emergency: 1-800-424 9300 (Chemtrec)
1601 McCloskey Blvd.
Tampa, Florida 33605 Technical Information: 1-800-368-1264
(813)248-1988
2. COMPOSITION/INFORMATION ON INGREDIENTS
Ingredient(s) CAS Number % (by weight)
HIGHLY REFINED SYNTHETIC BASE OILS 64742-54-7 < 87.0
AUTOMATIC TRANSMISSION FLUID ADDITIVE MIXTURE < 14.0
WITH POLYALKYLMETHACRYLATE CONFIDENTIAL VICOSITY INDEX IMPROVER MIXTURE < 14.0
I don't think any of the after market ATF brands are manufacturer approved, they just claim to meet or beat the specs.
Where are you getting the Amalie for $5 shipped?
I did not read EXCEDES all specification specs but, "may be used" and is "INVENTORY OPTIMISED". I think that means that transmissions shops will add an additive package to that fluid to make it meet specs. I prefere to stick with a manufactures RECOMENDED" ATF rather than a one that is suitable for all. JMO Ed
I use Amalie ATF (I think same to Wolf's Head) in my Nissan Maxima 2005 where Matic-K is required. Great product.
Is one fluid having claims of meeting ALL of those specs? That is impossible and if it does claim to meet ALL of them even the CVT specs in that list, something is rotten!! Regular ATF is deadly to CVT transmissions!! I have read horror stories about Honda and other CVTs being filled with regular ATF and needing to be replaced very quickly after that. It is a very expensive mistake that some shops make and it leads me to believe that if you have any CVT in your vehicle you have to watch the shop servicing the car like a hawk because it is a very easy mistake to make and a costly one. I would be very careful with these universal fluids since what works fine in one car can cause misery with another car. I have a Volkswagen but had a Chrysler with the A604 transmission before that and so I have always been very careful about fluids. The A604 that Chrysler used is one of those transmissions that is ruined by pretty much ANY other fluid and that is a known fact. The fluid they required had a specific additive that was needed.
A lot of those specs are mutually exclusive in terms of viscometrics as well.
It is not physically possible to meet the requirements of Mercon LV/ Dexron VI and Mercon V at the same time.
Exactly my point.
Lets not forget SP and type f.
Is there anything this fluid cannot do !?!?
I wonder if I can use it in my space shuttle?
Edit ... Oh wait, never mind. International Hy-Tran is not listed ... There goes that idea .... Darn it!
