I got a OEM Mazda V6 oil filter (p/n: JEY0-14-302 -9A) cut open today and was very impressed at how well built it is. I already knew Mazda sells very good oil filters for their older cars and this is confirmation that this is still happening.
There's pics around the web for the Tokyo Roki made Mazda filters as well as the Tennex ones. Tokyo Roki filters are rarely supplied to the US market and are primarily served for Asian markets. Tennex was bought out from Mahle around 6-7 years ago so Mazda USA no longer sells filters made by Tennex but sell Mahle ones instead (interestingly, the blue Mazda Canada filters are Tennex ones, I will have to guess that they never ran down their supply to need reordering).
Nowhere on the filter is "Mahle" printed on it, but the logo exists and tells you it is a Mahle if you recognize it.
Just like other Mahle filters, it was very difficult to cut the can. The metal is very thick and therefore can hold a lot of oil pressure (good for those autobahn runs and weekend races ). The element was very well glued together with metal caps on each end. Removing the metal caps as well as unfolding the element involved some destruction (from brute forcing) in order for it to happen.
I counted the pleats to be 117 and spread out to a length of 5'4" (I forgot to measure the width, I'll have to guess its around 3" to 3.25", I will look monday)-- an insane amount of filtration area for a 65mm X 85mm filter!
Enjoy the pics:
FYI, I have no idea how many miles is on this filter, it was just sitting in the pile ready to be crushed. Regardless, it held up very well and NOTHING got disformed inside unlike cheaply made filters
Enjoy the pics:
