Any harm in using a Motorcraft FL910S on a Tacoma?
by jongies3
05/28/16 08:50 PM
A/C performance woes...
by SEMI_287
05/28/16 08:49 PM
Red Line 10W30 Motorcycle oil particle count
by bulwnkl
05/28/16 08:08 PM
Microgard 51334 cut open
by dlundblad
05/28/16 08:07 PM
Differential Fluid Selection..
by Warstud
05/28/16 07:13 PM
The morality of riding a bike married with kids
by fdcg27
05/28/16 07:00 PM
Best synthetic oil for cleaning out an engine.
by anylettuce
05/28/16 06:58 PM
2013 ford fusion AC stank.
by leeaspell
05/28/16 06:46 PM
Cesna Citation Mustang - First impressions
by OVERKILL
05/28/16 05:35 PM
5.4 3V under valve cover pics & solenoid failure
by 04SE
05/28/16 03:50 PM
New safety spec for 2017 F1 cars...
by mcrn
05/28/16 03:35 PM
M1-101 after 10k on a 95 Sunfire 2.2 OHV pushrod
by slacktide_bitog
05/28/16 03:18 PM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
93 registered (04SE, advocate, 2015_PSD, 29662, ag_ghost, abycat, 6 invisible), 1434 Guests and 328 Spiders online.
58001 Members
66 Forums
249539 Topics
#1545938 - 07/27/09 01:18 PM Difference between 10w-30 versus 10w-40?
snakyjake Offline
Loc: USA
I understand the 10w, meaning the winter viscosity. But what is the difference between 30 and 40?
The 10w makes sense...lower rating means oil flows thinner at low temperatures. Therefore better lubrication at startup when it's freezing.
30 vs. 40?
40 weight is thicker (not sure how much more), but not sure what the advantages are. Less oil consumption with the 40? Better for old and loose engines? Does the 40 provide better protection and more cushion/compression against metal?
What advantages/disadvantages are with 30 weight?
Is there a problem stretching the oil viscosity chains from 10-30 to 10-40 (differences of 20 vs. 30 spread)?
Thanks,
Jake
#1545953 - 07/27/09 01:35 PM Re: Difference between 10w-30 versus 10w-40? [Re: snakyjake]
addyguy Offline
Loc: Canada
'Upper' oil weight are 'ranges' of viscosities at 100 degrees C, measured if centistrokes (cst).
A 30-weight oil is between 9.3 and 12.4 cst at 100C. A 40-weight oil is between 12.4 and 16.8 cst at 100C.
So, you can have 'thin' and 'thick' oil within the same oil grade - ie, Havoline 5W-30 is 9.7 [email protected]; while Maxlife 5W-30 is 11.5 [email protected]
Viscosity Index Improvers (VII's) are what make muti-viscosity oils thicker. Generally, most on here see them as bad things - they don't lubricate well, and they 'break down' and can get cooked into sludge - but this was much more true 25-30 years ago than today.
There is a huge, huge debate here about whether thicker oils actually protect better, or whether thinner ones do - you'll have to read all those threads for yourself.
Often, if an engine has a lot of wear, a thicker oil will reduce oil consumption by reducing the amount of oil that can 'escape' through larger openeings, but not always.
2010 Kia Soul 2U - 2.0L I-4, auto, 85k miles.
QSGB 5W-20, NAPA select filter(?)
#1545963 - 07/27/09 01:46 PM Re: Difference between 10w-30 versus 10w-40? [Re: addyguy]
hate2work Offline
Loc: Western Washington
Jake, are you still running the AME from Amsoil? That's a great oil, for sure.
#1546176 - 07/27/09 06:13 PM Re: Difference between 10w-30 versus 10w-40? [Re: snakyjake]
d00df00d Online   content
Loc: PA
 Originally Posted By: snakyjake
30 vs. 40?
Sometimes, yes, and yes. Disadvantages are increased drag, higher temps, and slower circulation in tight spaces; these may or may not be significant depending on the engine and conditions.
Depends. Synthetic or dino?
All else equal, a bigger spread means higher volatility and a greater need for VIIs (as addyguy mentioned). This might be an issue with a dino oil, but not so much with a synthetic.
2011 Mazda RX-8 R3
Castrol GTX 5w-20
#1824201 - 03/20/10 09:02 AM Re: Difference between 10w-30 versus 10w-40? [Re: d00df00d]
jorton Offline
Loc: San Antonio, TX
The upper number 30, 40 represents viscosity at normal summertime operating oil temperature. Viscosity is resistance to flow. Hot oil is thin so it needs to have some resistance to flow in order to prevent metal to metal contact. 20 and 30 weight oil has correct viscosity for new domestic gasoline powered passenger cars and trucks.
Switching to 10w-40 is common RX for older cars that have or may have low oil pressure.
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
#1824790 - 03/20/10 05:39 PM Re: Difference between 10w-30 versus 10w-40? [Re: jorton]
ps49556n Offline
Loc: NYC
Follow your mfgs guidelines, otherwise use a series of UOAs to determine the best viscosity.
#1824830 - 03/20/10 06:09 PM Re: Difference between 10w-30 versus 10w-40? [Re: ps49556n]
beast3300 Offline
Loc: Ohio
Viscosity doesn't equate to protection. For the most part 10w40 is obsolete. We service cars/trucks from small to big and use the recommended viscosity. All the Ford trucks with gas motors get 5w20 regular oil, even F350s.
I personally have used 5w30 in my supercharged Regal since fall of '08 to now. In my opinion 10w30 is obsolete in most situations, both in cars built from the 80s to now.
'03 Regal GS L67 3.29 GR:, PUP 5w30/TG3980, Filtermag
'99 Grand Prix L36: QS Defy 5w30/TG3387A, Filtermag
#1824839 - 03/20/10 06:20 PM Re: Difference between 10w-30 versus 10w-40? [Re: beast3300]
Catera Offline
Loc: Michigan, USA
The thing is if you have an 80s or 90s ride, you cant just jump to the 5W-20 oil, you will find yourself in a lot of trouble...
If you got an older car and its running fine stick to 5W-30 winter and 10W-30 summer, if it burns some oil try the 10W-40 and see if it helps.
If you got a new ride, lets say 2005-up and it says to use 20weight oil then do that, dont go 30-40...
Engines of each era are calibrated and designed in a specific way and its best to stick to those regulations...
My car suggest 10W-30 or if very hot a 10W-40 oil but in winter if temps are way too cold it calls for 5W30 or even 0W-30... for say up at the north pole...
2K1 Cadillac Catera Sport
L81 54 V6 24V 195RWHP 142.5K
Latest oil change.
5qt Mobil 1 HM Non-EC(10W-30)
3/4qt HDMO Rotella T (15W-40)
8oz. MMO
