Originally Posted By: Ike_Clanton
I think you're supposed to conclude Amsoil is, you know, awesome.
Remind me why Amsoil isn't sold in stores again?
Originally Posted By: doitmyself
Another question I have is: what can we conclude by comparing one performance characteristic between various oils.
For example, what does it tell me if I compare only the TBN of 10 HDEO oils? Is the one that has the highest TBN equal the best oil?
You see where I am going with this. Form your own conclusions.
Is the basis of the new Amsoil test similar in regard to the four ball wear test? I don't know, please tell me:
ftp://ftp.astmtmc.cmu.edu/docs/diesel/hdeocp/minutes/2001/hdeocp.2001-06/0601ATT18.PDF
"KURT ORBAHN SHOWS MAJOR MISALIGNMENTS WITH REAL WORLD, NOT APPROPRIATE FOR PERFORMANCE EVALUATION OF HD OILS"
Seems like you guys are trying to say something. If we only had this level of fortitude and balance with the pop oils.
There's an existing thread here:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1172315
Which begins to address the validity of the ASTM D-6278 test.
Also we have:
http://www.swri.org/4ORG/D08/global/ShearStb/default.htm
http://engineers.ihs.com/document/abstract/RYYZXAAAAAAAAAAA
I don't have the spec on this computer, but I'll read the whole thing on Monday.
It's a single lab test. Again, as I say about all tests, including the 4-ball test. It's a single bench test. No more no less. Schaeffer's uses it, other GOOD oil companies use the test. It's referenced here:
http://www.astm.org/Standards/D4485.htm
As for the 2001 Orinite presentation, I'm not sure whatever became of that but ASTM D-6278 has gone through two revisions since then, and the seems to be more widely adopted since then. I see some errors in the paper as well. Just because it's from Chevron doesn't mean it's not biased (you guys can spot bias, right?)
And of course ads for a product are supposed to say a product is awesome. Why would we think otherwise?
And yes Amsoil is sold in many stores, but what the heck does that have to do with this thread?
