try some searching,this has been posted before,lots of good reading here on this subject.
few posts bellow this one..
yeah i know MOST of it is for auto tranny 4wheelers and i don not have an auto. so ill need the wetclutch protection as well... what seems to be the better oil dino and or syn that does have the wetclutch additives as well?
No man,,that IS for wet clutch use,any HDEO will work,i like synthetics my self to help protect with the high heat these air cooled engines produce but 15w40s work very well also.
any HDEO 15w40 or 5w40 is where it's at.
so even for the wet clutches you can use a HDEO?? also can you give me an example of good HDEO's syn and dino? sorry man i dont know much about that oil at all..
Spend some time reading in the MC/power sports forum lots of good reading there,yes even for wet clutches it's fine to use,what you do not want however is a oil with a high amount(PPM)of moly,thats what could make a clutch slip,but HDEOs don't have that moly so it's fine and highly recommended to use,that's all i use in my Yamaha warrior.
