According to the manual, Toyota recommends a "Dex" type ATF fluid for the power steering. My question is though... since I have read on here that Dex VI is ONLY backwards compatible with transmissions that used to require Dex III. I can't find Dex III anywhere and I am not sure if I should use Dex VI in the power steering when I go to replace it. Is there an equivalent to the old Dex III that I should use for the power steering or what?
BTW... I just flushed out 2 quarts of power steering fluid on my 02 Olds Intrigue with 87,000 miles on the original fluid. That fluid was nasty! I am going to get another quart and flush it out in a week, as it still looks a little nasty. The power steering seems to operate a lot better now though.
