Hi people, for years and years I've been using Kendall Super Blue L-427. However it's becoming more difficult to find.
Can the guru's here suggest another extreme pressure grease that's compatible with what I've been using.
Thanks, Ray
PS I also use this grease in the thrust bearing on my Big Block Jet Boat...so it must handle EP, heat, high RPM loads.
Thanks, Ray
