Hey, I was changing the oil on a 2006 Toyota Sienna LE and the drain plug came out fine. Last time I changed it I torqued it to 20-25lb-ft and this time I didn't even get to put 5lb-ft on the plug before it started spinning.
I got the car warmed up first for obvious reasons, but I heard when you change spark plugs you can strip the threads if you change them while hot. So, does this apply somehow, because I can't figure out how or why the oil pan's threads would come out on the drain plug when it hasn't been overtorqued, for future purposes.
My first time for stripping an oil pan and the only other time I stripped something was on my dirtbike when the suspension bolt came out very stubbornly and when retoruqing I misread the sheet saying 50lbft instead of the 25 it was supposed to have. My bad.
As of now, the plug will go in and come out fine, you just cant put any torque on it. I got some blue threadlock on the plug and we're letting it set now. Should we try a helicoil or something or maybe a new oil pan?
What do you think?
What do you think?
