Originally Posted By: FL-400S
Originally Posted By: beast3300
The check plug is on the pass side axle housing. Its a 11mm plug that you remove with the vehicle running at normal operating temp on level ground. A drive on lift is the best way to do this.
The trans is treated like a differential. If nothing comes out of the little check plug, then you add to the large red cap. Once the fluid is level then the trans if full.
Some shops have flush machines, generally a pan drop is better because you don't introduce possible junk from another transmission previously serviced. Also replacing the filter screen is a good idea. The pan gasket is reusable, just wipe off and reuse.
Whichever you decide, I would recommend Dexron 6 trans fluid. It works very well.
I dont have access to a lift. When I change oil I dont even use ramps or anything
I guess I could drive it up on 2x4 for a bit more room to work?
Manual says Dexron III. I'll definitely put in synthetic.
As long as the car is level you can check it. Dex 6 is the only spec that is license and recommended by GM. The Dex III is not supported so the DEXIII stuff you see is sold is questionable.
Alldata lists 6.9 qts as the refill capacity for pan drop. I would start with 6.5 as inital fill. If its overfull then it will simply run out of the check plug
