Quote:
Hey Sayjac that procedure on that site is OK, but I think you'd need more than 3 totally fill and drains to get most all of the old coolant and the superflush that is added. I think you might need 5 or more. I would probably skip the superflush if the cooling system didn't look bad and especially if I was using the exact same type of anti-freeze since you'd be flushing a lot of water through it anyway.
I would open the block drain if at all possible.
Well, Prestone Super Flush is only 22oz, or a 1 pint + 1/2, so compared to the total capacity, it's miniscule. Also, with 2 complete distilled flushes after the Super Flush, I'm satisfied I've gotten most if not all out, or it's so diluted the remainder as it to be a non factor.
Also Prestone Super Flush is a relatively mild cleaner, basically citric acid designed as a ~10 minute flush, I generally give it at least 45 minutes with the heater wide open before I flush it out. And if you read Prestone's
directions for the product, it says put in radiator, run till hot,
then drain and refill with coolant. As it's designed primarily as a radiator flush, there's little concern on my part about multiple drains afterward, 2 should be plenty.
All that said, my post said generally follow that procedure, which I do like. The Super Radiator Flush is optional, but I figure as long as I'm doing a flush series, it can't hurt.
As for the block drains,
ideally that would be the way to go. BUT, that also requires getting under the engine block and getting a wrench on them to open them to drain. Unfortunately, that is
not always even generally practical. As an example, on the 01 Honda Civic, the block drain is on the back side of the engine immediately above the oil filter, meaning the oil filter has to be removed, an that you can get and reach it and loosen it after that, with a socket. In other words, a
pita. It also means getting many vehicles up on ramps before you can do the flush.
And that all assumes you can find the block drain(s), which as a rule are
not listed in the owners manual. Neither Tacoma nor Altima owners manual show where the block drains are located.
So, the procedure I follow in the link eliminates all the issues attached to using block drains. Ideally, block drains are great but practically, for the average joe (like me), doing it in his garage at home, generally the flush series is just easier.
