I emailed Shell about using Rotella T 5w-40 in a gasoline engine.
Yes, I know it has the SM cert. but I also know it's high ZDDP can wreck a cat or two. So, with all this in mind, I shot them an email. The following is their response:
Mr. Wickerham,
Rotella T 5w-40 meets both the API CJ-4 and SM specifications. It can therefore be used in Gasoline as well as diesel engines.
We do not recommend for use in engines with catalytic converters that require ILSAC GF-4 specifications.
Best Regards,
Technical Service
So, my question is: How do I know if my cat requires ILSAC GF-4? I just bought and installed it over the summer and don't wanna kill it prematurely. It's a Carsound by Magnaflow.
Mr. Wickerham,
Best Regards,
Technical Service
