Originally Posted By: Gary Allan
Quote:
Okay - so now the question is under what circumstances do you think it would be beneficial to use an oil that does not (or may not) support operation to near 100% of capability almost indefinitely?
Most of us get to use relatively mundane oils due to our power density. We have none of any appreciable amount ..so we don't need PF Flyer oils with the action wedge to make us run faster and jump higher. We're mostly trotting along.
..but I'll retort with another question. If BMW, MB, VW/AUDI were operating at 80-85mph ....in top gear ..would they need 10w-60 ...or whatever oil that the engineers spec'd for them? Why are these finely crafted engines ..with Teutonic ingenuity oozing (cleanly wiped up with a sterile white cloth) from every pore ...incapable of accomplishing what common grunt domestic droll stuff can do on totally junk oil??
Or are our traditional engines (not so traditional anymore) just too dumb to know that they should be wearing themselves to death?
Nope. I won't buy it.
This is not to say that I'd recommend it to anyone.
The question you pose is non-sensical - the BMW oil specs are designed around usage in and tested upon BMW engines. Using the example of a different engine with a different oil specification to try an draw inferences about the performance of BMW spec oil in BMW engines is quite the non-sequitor.
And FWIW, the 10W-60 is specified for use in only 2 BMW engines - the S54 and the S62's built up to 2/2000. Most other engines simply call for an LL-01 which is going to be either an xW-30 or an xW-40
Quote:
they do - that's why the API, ACEA, BMW, MB, etc. specifications are comprised of a whole battery of engine and lab tests rather than just one test. Additionally, that's where the service indicator comes into play. for the past decade or more, the service indicator on BMW's is not just a mileage countdown. The exact functioning varies by model and year somewhat, but in most of the more recent models it is driven by fuel consumption rather than mileage.
These are issues of oil longevity ..not self destructive wear.
You're telling me I can't use SJ oil because my GM oil life monitor isn't calibrated for it (no, you're not saying this).
So? Assume that I'm going to change it at 10% of whatever the Teutonic geniuses dictate and to heck with what they think.
The OEM specifications are based around assuring a certain level performance over a certain duration. If you choose to deviate from the oil specification, you no longer can assume effectiveness for that performance duration. Exactly when and to what degree the consequences of that deviation reveal themselves is subject to many many variables and of course you may choose to adopt strategies to mitigate those consequences.
In the example you cited, SJ vs. (presumably) SM, what you are looking it an oil subject to:
* higher volatility
* less stringent water tolerance
* higher foaming
* higher deposits
* greater tendency to sludge and varnish formation
* and, yes, potentially higher wear as SJ has no ASTM D 6891 engine test requirement
I don't know how your GM OLM determines it's result, but it's determination of a safe OCI is based on SM oil performance, you will likely get different performance results by using an SJ instead. Based on the particular circumstances of your operation of that car, those results might be inconsequential, but it's even more possible they are not. As before the question is, just what is it you would expect to gain from running an SJ to make it worth accepting the risk?
* higher volatility
* higher foaming
* higher deposits
