BG requires their service providers to use the #9210 pressurized "inject-a-flush" apparatus to deliver the BG ISC chemical for an induction service. As an alternative to the costly device, I think I've found a solution that will deliver nearly the same results. In the picture above, I have a 30" long straw attached to a can of Amsoil Powerfoam. The straw has two small holes at one end, which allows it to deliver a "fan" of the cleaner. Here's why I think this solution will work just as well as BG's method:
1. By using this straw, you are able to feed the chemical SLOWLY, thus eliminating any chance of hydrolock.
2. With the long straw, you are now able to introduce the chemical through the intake manifold. This is the best way of introducing the chemical since on some vehicles, a vacuum line may not allow the chemical to reach all cylinders.
3. The quantity of chemical is just as important as the rate at which it is being introduced. When the chemical is introduced slowly, say over the course of five minutes, it will slowly and continuously clean the intake valves, piston tops and the intake area. When you quickly feed a large quantity of chemical into a vacuum line and stall the engine (as directed by the SeaFoam website), the chemical isn't able to reach all portions of the induction system.
4. There are two small holes at one end of the straw, which allows you to deliver a "mist" or a "cloud" of the chemical so that the chemical will thoroughly clean the gunk from the entire intake manifold. Personally, I think that's the reason why BG's device is essentially a high-pressure mister that is placed at the entrance of the intake manifold-- so that the chemical mist can slowly soften the build-up inside the manifold.
What do you guys think?
