background: Snowblower transmission died last feb, I dragged it into a snowbank abandoned. Rained on it all summer. Pulled the good motor and recycled the rest.
Got a new blower chassis with an underpowered engine, put this (20 y.o. tecumseh 8 hp) bad boy on there, it runs (!) but sputters, stalls etc.
Drain the gas that was in it, may have looked ok, drained it into a red gas can so who knows.
Petcock leaves 1/4 inch of junk on the bottom of the plastic tank.
Cleaned carb. Was pretty clean anyway. Still stumbled.
Put fresh fuel and a dollop of seafoam in, look in, it's milky and bubbly. Suspect water but wonder if seafoam does this when mixed.
Removed tank and shook it every which way to really clean it out. Put fresh gas in. Grade A- performance!
