Originally Posted By: Ndx
Question is JB Weld - brake fluid resistant ...
I have Motive Bleeder but I don't have compatible cap ...
So I'm making my own - I drilled hole .. and I'm using Brass Fitting ... but It has to be air tight ... so I need some good sealer ...
Actually, I also have a Motive bleeder and did exactly that. I got an extra cap, drilled a hole for a brass fitting, then used a glob of red MarineTex on both sides to make doubly sure the threads were pressure tight. That was about 8 years ago and lots of usage. I generally don't go much above 12psi or so. JB Weld will probably work just as well.
Good luck.
