I have a 3 year old Toro Recycler with a Tecumseh LV148EA that will not start. It worked fine the 1st summer but since then every once in a while, it won't start. It smells like it's flooded. I have taken it apart, put it back together & it has started. The only things I have done while it was apart was drain the carb, checked to make sure the float moves, cleaned the contact on the wire to the ignition system & cleaned the spark plug. Not this time, I am running out of patience.
The mower has had regular maintenance. Every spring, changed oil, new spark plug, new air filter (twice a year) & new blade.
This is the first mower I have had with a Tecumseh Engine. All of my other mowers have had B & S. Never a problem.
The mower this one replaced was used for 16 years. It always started on the first pull, ever on its first use in the spring. One time I forgot to drain the gas in the fall, it started with no problem 4 months later. It's unfortunate the mower itself was falling apart or I would still have it.
Any advice would be appreciated. Thanks.
