First time poster here so I hope I ask a somewhat intelligent question.
I am the new owner of a 06 mini cooper S. Mini recommends Castrol 5w-30 synthetic. But supposedly the stuff you are able to buy at WM is different than what you buy at the dealer. So many recommend the European blend Castol 0w-30. This is alittle harder to find and I have not seen it at WM. There are also several different Mobile products that would work.
But on Mini's USA site, they list several alternative oils that meets their spec. Among the listed oils is Valvoline SynPower 5w-30.
Now for my question. I have tried using the search function here and if I am doing it correctly, have not found much info regarding Valvoline SynPower 5w-30 oil. For those of you who might know, how does it stack up against the others? Is it an inferior product and is that the reason why it is not mentioned here very much or are there other reasons?
I would appreciate any input you might be able to share. Also, if I am missing something on the search function, please lead me down the correct path.
Lon
Lon
