It is back. It is still on cylinder 1 as well. To reiterate what I have done so far; Last time I tried to figure out what was the problem, I tested compression, which was excellent. 170-175+psi on all cylinders. I also put it back together with some tactful component swapping. I put the spark plug from #1 in the #6 hole and swapped the 1-4 and 2-5 coil packs. One thing I didnt swap is the spark plug wire itself. These are new, but I may do some swapping of those as well. Have to find one that is about the same length.
I thought this was only a cold start problem but I drove it once and after sitting for about 45 minutes to an hour I started it up with a very bad miss. Cleared up after about 30-60 seconds then ran smooth as butter.
Any suggestions?
Any suggestions?
