While I was changing a motor mount yesterday, I noticed that my axles were loose in their holes in the transmission. It's a 97 Grand Prix GTP (so it has the 4t65e-hd transmission).
(Apologies for not using the technical terms- I forget the names.)
I'm pretty sure they are the original cv shafts. By loose, I mean that I can easily wiggle the inner "cup on a shaft" thing- the piece that goes into the transmission and that the mid-shaft of the cv axle goes into. Probably a few degrees of play off of center.
Weird thing is that it's not leaking to any appreciable degree- a half a pint a year maybe?
My questions are, and I know this is mostly trying to read tea leaves:
1- I looked at some online diagrams of the transmission, and wasn't really able to tell- is there a bearing inside the trans that keeps the driveshaft in place? Or does it just "hang off" of the output shaft?
2- Do you think this is just worn splines on the driveshaft? Or could this be loose/worn parts in the output/differential part of the trans? I would hope that the parts in the transmission would be "harder" than the driveshaft, so that if wear was going to occur, it would be in the driveshaft and not the transmission. But who knows?
3- Any recommendations on good/economical brands of reman or new driveshafts?
I guess what I'll have to do is just get new driveshafts and see how they are once installed. It's an old car, but I really like it and want to keep as long as possible.
Thanks in advance!
PS- Wow, what a difference new mounts made- the right hand mount was completely collapsed and the engine was just sitting, metal to metal, on the frame. It happened gradually, so I didn't really notice that they were bad until they were really bad. I expect that this misalignment probably caused some of this problem. I used the cheap Anchor mounts, but I did get their hydraulic ones. They seem to be better than the usual garbage that Anchor has. We'll see how long they last...
Thanks in advance!
