Well, he may very well be. I really can't see why he couldn't. It's just an odd selection unless you just happen to have a spare fuel filter base hanging around. The filter has a 10um rating in WIX and it is the extended duty version. In this capacity, I imagine a number of hydraulic filters would do well too.
Descriptions: Fuel/Water Separator Base
Notes: This base requires the D-Ring, furnished with filter, for installation. Permits the addition of a remote mount fuel/water separator spin-on to most equipment. This is standard Cummins engine fuel filter mount.
Use_With: BF957, BF957-D, BF1212, BF1249, BF1252, BF1258, BF1259, BF1282, BF5801, BF5812, BF7557, BF7558
Contains: Bracket Bolt Holes
3/8-16 UNC-2B
Threaded Stud 1-14
O.D.: 3 19/32 (91.3)
Inlet: 7/8-14 UNF
Outlet: 7/8-14 UNF
Length: 1 15/16 (49.2)
UPC: 7 91440 01182 3
