Originally Posted By: oilboy123
Engine only 1000lbs? Or the trans/engine?
Engine only. With manifolds and water pump. The 266,304,345 and 392 IHC engines are a medium duty truck engine. They came with a 100K warranty back in the 60's.
They have extreemly hard blocks. A lot of machinest's don't like to bore them because the block will eat several bits.
Steel cranks.
Sodium filled valves and hard press in valve seats.
Each engine was hand assembled by 2 employees and were balanced.
