Originally Posted By: HondaMan
Much is being noted about how ... "If they are using the product right off the shelf.... If Honda uses ... etc etc"
I would say that all present users of M1 including auto makers ASSUME that the oil is what it is SUPPOSED TO BE.
I contend that the present batch is NOT what it is SUPPOSED TO BE.
Will your engine suffer because of this, I believe not really.
Will you have LESS WEAR with another product at present, I belive yes.
Do you really think Porsche, Merecedes,GM,Viper,Auston Martin, and all the rest assume anything that they require for their vehicles? They take R&D seriousley. They don't assume anything.
tigi,
This is exactly what I referring to .... all the auto makers you mention above do testing, have R&D, etc etc. They decide, YES, this product passes/meets our standards based upon our testing/r&d etc etc.
At this point, again, they ASSUME the product to be what they experienced during their evaluation. They can't test every bottle, they have to ASSUME the formulation is what it is supposed to be .... there begins the problem.
Unless there isn't a problem. Perhaps the Seq-IVA test results have no bearing on the testing performed by Porsche, MB, GM and Honda?
