Here we go.............
I love it! Us GC users have elves, so I wonder what we call the little Valvoline brewmeister?quote:
Originally posted by TallPaul:
If everyone used tight fitting OEM air filters and the manufacturer's would fix the internal coolant leak problems, we'd be bored to death.quote:
Originally posted by Geoff:
Despite beating this topic to death I still find this interesting. Silicon is pretty much the only item on the analyses that is consistent with high wear metals.
Don't miss quote the article.quote:
Originally posted by bigpaulo:
from this discussion of viscosity, velocity and operating temperature on hydrodynamic lubrication
Any increase in viscosity results in increased operating temperatures, thus reducing the viscosity, and tends to have a neutral affect on film thickness.
Thicker may be better, given the same contamination level *AND* velocity *AND* operating temperature. Those are big ANDs.
See the guy with the Ferrari running 20W oil, seeing lower operating temperatures, which results in thicker film thickness (all other things being equal... the bulk temp might be lower, but localized temps may be higher in spots, which would be my concern, but if UOAs show good wear metal levels, then he wins!).
Well, I READ about the guy who has the Ferrari,and his claim about lower temps, but, you know something.....I have a sneaking suspicion that the Maranello engine guys spec'ed the oil they do for a reason. IMO there is more to an engine/lubricant system than just sump temps and wear metals in the oil.quote:
from [
I might note that one can increase the viscocity of an oil by using it at a lower temperature!quote:
From The Practical Handbook of Machinery Lubrication (bold my emphasis):
quote:
In general, the important parameters influencing bearing wear are contaminant particle size, concentration, hardness and lubricant film thickness. Increases in all of these parameters except film thickness will increase bearing wear.
Increasing lubricant viscosity will reduce bearing wear for a given contamination level.
You said it yourself... never saw track time... only driven around town... I am guessing (yes, guessing) that that engine rarely was brought up to operating temperature while driving. You could be running D1 and still get high fuel dilution under similar circumstances.quote:
Originally posted by JohnBrowning:
Did you see how fuel diluted his Ferari's oil sample was? It could be a ring sealing issue? The milage was also rather low on the sample and it is a hand built engine useing raceing technology and design. If I remember correctly it the sample did not have any track time on it either it was all around town driveing. ...
