Thanks for the quick answer. To give you some feedback I must say that I'm very pleased with this oil - at minus 10C the car starts like in summer time. The oil pressure light goes off instantly after startup. Also the time needed to lubricate the hydraulic valve rockers is very short only about 2 seconds then the engine is runing smooth.
Any advice of full syn to use instead? (I want to keep the 5W40 range).
