Be careful with the x-references. I looked up a WIX by make and model and get 51069 oil filter.
When I x-ref I don' get the same number you got. If its an AC Delco the correct part number is PF25.
Make Year Model Engine Filter Type Premium Part Standard Part
CHEVROLET 1969 CAMARO V8 5.4L 327 CID Air 42083
CHEVROLET 1969 CAMARO V8 5.4L 327 CID Breather 42995
CHEVROLET 1969 CAMARO V8 5.4L 327 CID Breather NR
CHEVROLET 1969 CAMARO V8 5.4L 327 CID Fuel 33050
CHEVROLET 1969 CAMARO V8 5.4L 327 CID Lube EAO25 51069
FILTER ASM,OIL
Part Number: PF25
Product Notes:
[Oil Filter];2 BBL ; w/out anti-Drain back valve ; Featuring classic ac logo
Pack Qty: 1; Per Vehicle: 1; Years: 1969-1969
Newer style AC Delco is this one
FILTER,OIL
Part Number: PF454
Product Notes:
[Oil Filter];2 BBL ; w/ anti-Drain back valve ; 81mm long
