I read posts complaining about Water Wetter leaving a brown substance in their overflow bottle. So I thought I'd try Diesel Water Wetter. Redline told me it would work okay. I wasn't expecting one bottle to be intended for a 10-15 gal. cooling system, and since my cooling system holds 8 5/8 quarts I'm not sure how much to use. I was originally planning to use 50% Prestone Long Life antifreeze which would supply enough corrosion and other additives. But if I'm going to use a product like WW why not use less antifreeze since I'm in a warm climate. The record low here is -8 degrees F and 40%/60% antifreeze to water will protect down to -12 deg F. So is there another additive I should add to prevent corrosion. Or should I take the Diesel Water Wetter back and get similar product with lubricants and corrosion inhibitors that doesn't leave brown deposits in the coolant?
