I'm hoping that someone can give me some insight on my transmission issue, as I'm not too knowledgeable when it come to automatic transmissions.
Several months ago, I went to stop and the transmission keep pushing as I applied the brakes - I had to brake really hard to get the truck to stop. The transmission had always performed well up to this point. I went to my mechanic and he said it was probably a sticking shift solenoid. Since I was about 2500 miles from my scheduled maintenance, he suggested that I just keep an eye on it and come back if the problem reoccurred. It has started to happen frequently, although not nearly as bad as the first time. It also seems like its not shifting into over-drive. I can get the tach to 6000 rpms (highest number) without the last shift. I also fell a vibration at shift points when the vehicle is cold. After describing this to my mechanic, he said it was probably torque converter "shudder". I have stopped driving the truck, and will get it to him as soon as possible - early to mid week. Any ideas about what problem could be?
I added 6 ounces of Auto Rx, but don't know if I should wait 1000 miles to see if it does the trick.
