Hi all, my friend brought over his sister's '99 GMC Sierra 1500 4WD today for an oil change. I drained the oil and removed the old oil filter that Wal-Mart put on previously (so tight my hand is bruised and the can looks like it's been through a war because of the warfare I had to use against it) and it was a Fram PH3980. I purchased another 3980, except it was the AAP Totalgrip AA3980, which is the same size. I then looked into the manual and saw that the truck only had a 4.3 V6, 4.8 V8 or a 5.3 V8. He told me he thought it was a 5.7, but from what I understand they didn't make the 5.7 for the Sierra that year. The manual said 6 quarts for everything except the V6 and I'm pretty sure it wasn't a V6. Fram's "guide" showed the PH3675 for the 5.3, which is what I think the truck actually is. I should have paid closer attention to see how many spark plugs it had to see if it was the V6 or V8.. I just put the 3980 on with 6 quarts of oil and didn't have a chance to check the level because he was in a hurry to get home. There were no leaks or strange noises and the oil pressure registered after about 2-3 seconds and he said it ran fine on the way home. I'm going to go to his house tomorrow to double check the fluid level and the engine, but does anyone know what I should look for on the VIN to see what engine it has? From what I gather, it's the 8th character that tells the engine code for GMC pickups. But I don't know what the letters will mean once I do find it. I'm 99% sure it was the 5.3 V8, and the manual said it was engine code "T" for the 5.3, and I think I looked at the wrong digit in the VIN. I was looking at the 3rd character, which was the letter T. But, after looking into it further, the T actually meant "GMC Truck." The manual didn't help either, it didn't say which digit to look at in the VIN.
Also, did they actually make a 5.7 for that year? If it does turn out to be the 5.3, did I do the right thing by using the 3980 with 6 quarts of oil? If it does turn out to be the V6, I know the oil filter is right because Fram says it's the 3980 for the 4.3 V6, but I think that one only called for 4.5-5 quarts of oil... I'll have to drain some out in that case. Really bad day thus far, that oil change took almost 2 hours because of unfortunate setbacks and I know next to nothing about Chevy/GMC trucks..
I asked him to get me the VIN so I could post the 8th digit here but he said it's too dark out and he doesn't know where the flashlight is, so I'll find out more tomorrow. I'm thinking one of two things: Wal-Mart put the V6 oil filter on a V8, or it actually IS the V6 and I put too much oil in it... Hopefully the former.
Edit: D'oh, I meant to post this in the Mechanical/Maintenance forum...
