Originally Posted By: lovcom
I've driven in the rain several times, and found no noticable loss in traction with the tires up to 50PSI. I'm sure there is in fact degradation but a lot less then you might expect.
How many emergency stops have you made?
Several times. Before I made 50psi a policy, I tested the brakes in wet and dry conditions. I too had my doubts.
HAAAAAAAAAAA! You tested the brakes...
Try a full limits of the vehicle type braking and cornering maneuver, like if a deer ran across the road in front of you on a wet road. I guarantee your testing of the brakes was nothing compared to an actual panic driving situation.
