Says here that it should be 'flat rate time 0.8 hour'. So find out how much the parts are, and make sure they only charge you .8 of whatever one hour labour is.
______________________________
January 11, 2005
Applies To:
See VEHICLES AFFECTED
Squeak at the Clutch Pedal
(Supersedes 02-002, dated September 21, 2004)
SYMPTOM
A squeak, a twang, or a notchy feel when the clutch pedal is pressed.
PROBABLE CAUSE
The clutch master cylinder spring is rubbing on the outer diameter of the piston when the pedal is pressed, or the master cylinder quick connect is moving.
CORRECTIVE ACTION
Replace the master cylinder, and apply a thin film of silicone grease to the clutch line fitting.
REQUIRED MATERIALS
Silicone Grease: P/N 08C30-B0234M, H/C 6110928
Brake Fluid: P/N 08798-9008, H/C 4423802
PARTS INFORMATION
Civic/Civic Hybrid Master Cylinder
/N 46920-S5A-G04, H/C 7569452
Accord/Civic Si/CR-V/Element Master Cylinder
/N 46920-57A-A02, H/C 7604507
WARRANTY CLAIM INFORMATION
In warranty:
The normal warranty applies.
Operation Number: 211101
Flat Rate Time: 0.6 hour (All Civics)
0.8 hour (Accord/CR-V/Element)
Failed Part:
Civic/Civic Hybrid:
P/N 46920-55A-G01
H/C 6571103
Accord/Civic Si/CR-V/Element:
P/N 46920-S7A-A01
H/C 6729031
Defect Code: 03214
Symptom Code: 04201
Skill Level: Repair Technician
REPAIR PROCEDURE
NOTICE Do not spill brake fluid on the vehicle; it may damage the paint. If brake fluid does contact the paint, wash it off immediately with water.
1. Remove the clutch master cylinder.
Refer to the appropriate service manual:
2003-04 Accord (L4): page 12-6
2003-04 Accord (V6): page 12-8
2001-04 Civic: page 12-5
2002-04 Civic Si: page 12-5
2003-04 Civic Hybrid: page 13-5
2002-04 CR-V: page 12-5
2003-04 Element: page 12-6
Enter keyword CLUTCH MASTER, and select Clutch Master Cylinder Replacement from the list.
2. Install the new clutch master cylinder, but do not attach the clutch line fitting.
Apply a thin coat of silicone grease to the clutch line fitting and to the opening in the clutch master cylinder. Do not use silicone spray; it could damage the 0-ring.
4. Connect the clutch line fitting to the clutch master cylinder.
5. Bleed the clutch hydraulic system, then top off the reservoir with brake fluid.
6. Check to see if the noise is gone when pressing the clutch pedal.
^ If the noise is gone, the repair is complete.
^ If the noise is still present, look for other causes.
7. Test-drive the vehicle to check for proper clutch operation.
