2008 Honda Fit factory fill. Changed early based on little trust of the Honda owners manual in this area. Suspect it's 5W-20 as that is the oil weight oil recommended by Honda. Drive very easy 70% freeway.
Replaced with 5W-20 Wallmart Supertech. Will dump and test at 5000.
I think the high moly content is from an additive not the oil or assy lube.
Anyone seen a VOA on the factory oil????
