I'm already starting to realize the benefit of knowing how easily the exhaust ports can be cleaned on a 2 cycle Lawn Boy mower.
I bought a 2 cycle Commercial series Lawn Boy off of Craigslist for $40. It was a 1990 model, but it looked like new. The owner was selling it because "it was all stoved up", and he had stopped using it several years back. With only some fresh gas/oil mix, it started on the second pull, but it only ran at about 1/2 power. I knew what the problem was, and bought it on the spot.
Once I got it home and the muffler off, of the three exhaust ports, one was completely plugged with carbon, one was about 70% plugged and the third was about 50% plugged. The carbon was in the ports like cement. A 3/8" diameter dowel rod is perfect for cleaning out the ports.
After 30 minutes of work, it runs as good as it looks.
After it was able to breathe freely again, I shot a little SeaFoam into the intake while it was running using a syringe, and added two ounces of SF into a fresh gallon of pre-mix to clean the entire fuel system.
I appear to have ended up with a nice little bargain to go along with my 1983 Lawn Boy that I bought new with my own money when I was 13.
After seeing what the carbon build up will do to a Lawn Boy, and after studying much of the conversation here, I've decided to switch over to a synthetic 2 cycle oil, and try it at a 40:1 ratio. If I don't go full synthetic, I may try some of the Pennzoil Semi-synthetic Premium Plus 2 cycle oil that I buy in the gallon jugs ($10/gallon) for the 2 jet skis that I own. I'm going to hit two Advance Auto Parts locations this afternoon and see if I can find a quart (or two) of the discontinued Mobil 1 two cycle oil.
In the past, I've used Quaker State 2 cycle oil, but I don't plan on using it in the newer mower.
