These cat converters are prone to going bad anyway on the 01 corolla so I doubt it was solely because of the seafoam since I have smelled sulfur out of the exhaust for years. They warranty the cats up to 80k miles because of it. I also used b12 in the tank and crankcase so that may have contributed also since Ive seen on here that theyre no longer listed as cat converter safe.
Ive already installed a new oem pcv, new oem plugs properly gapped(the 01 has coils, no wires) with the ECU reset, recharged the air filter, cleaned the maf with crc maf cleaner, alignment was checked and is good, tires are up to proper pressure however I believe one pulls so I that could be contributing to low mileage although the low mileage started before I had that tire.
I just bought oem o2 sensors since its time to replace them so I'll install them and see if that helps. If not then a lot of people have had success with improving mileage in their corollas by replacing the temp stat, and if that doesnt work then I'll get a new cat converter since its time to replace that anyway.
