I agree with TDI Jerry. I just took my valve cover off of my 15 year old 120,000 mile BMW yesterday. This was a "wholesaler" car with absolutely zero service records for the first 100,000 miles. Sadly, from the evidence I have found it seems the previous owner "drove it and got out of it". When he found he needed brake pads, he traded the car in. Anyway, after Amsoil 10W40 over the last three years, I can see that the il is trying to clean things up but it is still a mess under the valve cover. I am going to start Auto-RX next.quote:
Originally posted by tdi jerry:
I DONT CARE WHAT KIND OF OIL YOU RUN WHEN IT GETS LIKE THIS THE SYS OIL WILL NOT CLEAN THE ENGINE UP. THE BEST SYS OIL CAN NOT CLEAN A ENGINE UP ONCE THE OIL GETS BAKE UP ON THE MOTOR PARTS.
I wish it were that simple for 1.8T owners, Don. Check out the horror stories on VWVortex.com and ClubB5.com, and you'll see what I mean. These cars desperately need oil pressure gauges, as well as drivers who know how to read early warning signs on these gauges. By the time the low oil pressure idiot light finally comes on, the engine is generally toast because of a clogged oil pump pickup screen. For many owners, abrupt sludge-induced engine failure comes on like an unexpected sudden heart attack, which also arises, often symptom-free, from gradual inexorable clogging of a vital circulatory system.quote:
Originally posted by Don Stevens:
... So for all of you VW guys (and others) with sludge and varnish issues, don't panic, just follow the advice of the experienced guys here and enjoy your cars.
Don
How much would it cost me to do before & after compression tests?quote:
Originally posted by moribundman:
Yeah sure, Auto-RX sounds like a GREAT solution in this motor. Make sure you do a compression test before you start treatment and another one afterwards so that you KNOW it worked.
