any harm done to Ranger?
by mobilaltima
23 minutes 0 seconds ago
Obsolete Freeway on ramps
by jimbrewer
26 minutes 3 seconds ago
Ideal-Tridon Hose Clamp Display
by Merkava_4
Today at 08:52 PM
Want to hear from turbo owners that go 10k + oci
by Sw296inchblue
Today at 08:31 PM
When you have found the right combo
by bbhero
Today at 08:25 PM
High Mileage diesel oil?
by Hysilver
Today at 08:23 PM
Barium
by Hullthumper
Today at 07:25 PM
Oil filters suggestions for a 10' Hyundai .......
by Oregoonian
Today at 06:32 PM
Is the spin-on filter's days numbered?
by jongies3
Today at 06:28 PM
Mobil 1 75w90 LS for 2010 Camaro SS
by AIRJAC3
Today at 05:51 PM
2013 Tacoma ATF Change?
by CrackyWainwright
Today at 05:42 PM
Blackfire Wet Diamond
by BlueOvalFitter
Today at 05:42 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
68 registered (AIRJAC3, 2015_PSD, ABomb369, ag_ghost, aquariuscsm, 6 invisible), 1345 Guests and 344 Spiders online.
58031 Members
66 Forums
249647 Topics
Page 1 of 2 1 2 >
#1110194 - 03/20/08 09:22 AM Cheat sheet for newbies reading UOA's
Bambam Offline
Loc: CT
I am trying to interpret UOA's. I get info through others comments but like most newbies I don't know alot and get confused by certain elements etc. So Ityped this up for all to print out and have next to them for guidance. To be added/edited as we all see fit.
Mods please move if this is unappropriate for this particular forum.
WEAR METAL SOURCES
IRON……….CYLINDERS, GEARS, RINGS, CRANKSHAFTS, LINERS, BEARINGS, HOUSINGS, RODS, and PLATINGS
CHROMIUM……………..RINGS,ROLLER/TAPER BEARINGS, RODS, PLATINGS
LEAD……….BEARING OVERLAYS, ADDITIVES IN GEAR OIL AND GASOLINE
COPPER…………………BUSHINGS, BEARINGS, THRUST WASHERS, FRICITION PLATES, OIL COOLERS, ADDITIVE IN OIL
TIN………………………………….BEARINGS, BUSHINGS, PISTONS, PLATINGS
ALUMINUM………PISTONS, BEARINGS, PUMPS, BLOWERS, ROTORS, THRUST WASHERS
NICKEL……………………………………………………………………VALVES
SILVER………………………………………….BEARINGS,BUSHINGS,PLATING
MANGANESE……….TRACE ELEMENTS IN LINERS AND RINGS, ADDITIVE IN GASLOLINE.
TITANIUM……………………………………………………….TRACE ELEMENT
VANADIUM……………………………………………………..TRACE ELEMENT
CONTANIMENTS & SOURCES
SILICON…………………………………….ELEMENT USED TO DETERMINE THE LEVEL OF AIRBORNE DIRT AND ABRASIVES IN THE OIL.(SOMETIMES USED AS AN ANTI-FOAM AGENT)
BORON………………………….PRESENT IN MOST PERMANENT ANTI-FREEZE SYSTEMS AND COOLING SYSTEMS INHIBITORS (SOMETIMES USED AS AN ADDITIVE)
SODIUM………………………………….PRESENT IN MOST PERMANENT ANTI-FREEZE SYSTEMS AND COOLING SYSTEM INHIBITORS (SOMETIMES USED AS AN ADDITIVE)
POTASSIUM………….PRESENT IN MOST PERMANENT ANTI-FREEZE SYSTEMS AND COOLING SYSTEM INHIBITORS (SOMETIMES USED AS AN ADDITIVE IN GEAR OIL)
ADDITIVES AND THEIR FUNCTION
MAGNESIUM……………………….DISPERSENT/DETERGENT ADDITIVE
CALCIUM………………………….. DISPERSENT/DETERGENT ADDITIVE
BARIUM………………………….. DISPERSENT/DETERGENT ADDITIVE.
PHOSPHORUS…………………………………..….ANTI-WEAR ADDITIVE
ZINC……………………………………………….…. ANTI-WEAR ADDITIVE
MOLBDENUM………………………………….…… ANTI-WEAR ADDITIVE
FUEL DILUTION = UNBURNED FUEL IN THE OIL MAY SIGNAL FUEL SYSTEM LEAKS OR INCOMPLETE COMBUSTION.
FUEL SOOT = A RESULT IN INCOMPLETE COMBUSTION OR BLOW-BY. HIGH DRAIN LEVELS AMY INDICATES COMBUSTION PROBLEMS OR OVEREXTENDED DRAIN INTERVALS.
VISCOSITY = THE KINEMATIC VISCOSITY DETERMINED AT 40°C AND/OR 100°C IS A MEASURE OF THE FLOW RATE OF AN OIL IN RELATION TO TIME. THIS DATA IS USED TO ASSIGN AN SAE GRADE TO OIL.
SAE GRADE…………….MIN-cST-100°………………MAX-Cst
10w……………………4.10………………………….xx
20w………………………..5.60……………………….9.29
30w…………………………9.30……………………..…12.49
40w……………………….12.50……………………………16.29
50w………………………..16.30………………………………21.89
07 DMAX CC 4x4
265 Goodyears
Bilstein 5100's
T-C pump rub fix
EGR Blocked
PCV rerouted
efi live tuned
Student of dnewton's dino teachings
#1110209 - 03/20/08 09:37 AM Re: Cheat sheet for newbies reading UOA's [Re: Bambam]
Johnny Offline
Loc: Retired | Wausau, WI
Very nice. This might be a good sticky at the top of the UOA section for all to reference.
Edited by Johnny (03/20/08 09:38 AM)
#1110356 - 03/20/08 12:43 PM Re: Cheat sheet for newbies reading UOA's [Re: Johnny]
ZZman Offline
Loc: Michigan
There should also be a similar sticky in the car section
2002 Buick Regal GS (3.8 Supercharged) PP, Pure 1 filter
2008 Sebring Hardtop convertible (2.7) PP, Pure 1 filter.
2006 Kawasaki Vulcan 900 LT
#1110929 - 03/21/08 08:24 AM Re: Cheat sheet for newbies reading UOA's [Re: Bambam]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Generally ok.....the viscosity table could be quite misleading. Atleast drop the "w"s Better to just post the whole table from J300: http://www.infineum.com/information/api-viscosity-2004.html
#1112483 - 03/23/08 03:42 PM Re: Cheat sheet for newbies reading UOA's [Re: Pablo]
D-Roc Offline
Loc: quelque part
Awesome- great for those who are up on their UOA knowlege, but like who need a quick reference once in a while.
#1112628 - 03/23/08 07:49 PM Re: Cheat sheet for newbies reading UOA's [Re: D-Roc]
Steve S Offline
Loc: East of IGO
Any one know where a condemnation limit chart is posted?
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1124509 - 04/08/08 07:41 AM Re: Cheat sheet for newbies reading UOA's [Re: Steve S]
Jim Allen Offline
Loc: NW Ohio
Excellent work, Bambam. Thanks for taking the time to do it.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#1200118 - 07/23/08 11:36 AM Re: Cheat sheet for newbies reading UOA's [Re: Jim Allen]
RWEST Offline
Loc: Somerset County, PA
So, to help out an oil-dork, what should the numbers be for a multi-vis, say, RTS 5-40?
"even if you're paranoid, they can still be following you" hide
"live so the preacher doesn't have to lie at your funeral" wink
#1212098 - 08/09/08 06:42 PM Re: Cheat sheet for newbies reading UOA's [Re: RWEST]
D-Roc Offline
Loc: quelque part
For Admin, would it be possible to update the above info with oxidation, nitration and sulfation? This one specifically for myself, just a reference of the numbers on what is high and low. But also for others.
I know one way they are measured is using a spectrometer with how much infrared light is absorbed by the products of oxidation, nitration, sulfation, but not what is acceptable, high and low. Some uoa's also are coming through with just the number...Blackstone usually has perameters/guidelines, but some don't.
#1218196 - 08/17/08 10:25 AM Re: Cheat sheet for newbies reading UOA's [Re: D-Roc]
lewdwig Offline
Loc: Southwest Michigan
I'll look for something on TBN and include it.
1996 Saturn SL2
2001 Saturn SL2
2001 Subaru Forester L
2004 Mitsu Endeavor
Google search:
(search terms here) site:bobistheoilguy.com
#1379270 - 02/19/09 04:14 PM Re: Cheat sheet for newbies reading UOA's [Re: lewdwig]
TSHACK Offline
Loc: Virginia Beach, Va
AWESOME!!
2003 Supercharged F150 Harley Davidson. Mine
2011 Jeep Wrangler Unlimited. Wife
2002 Acura CL 3.2. Son
2010 Sentra SE-R. Daughter
AMSOIL in all of them.
#1539320 - 07/21/09 12:26 PM Re: Cheat sheet for newbies reading UOA's [Re: TSHACK]
bloc Offline
Loc: Houston, Tx
I also wanted to request "condemnation" limits, or at least numbers at which we should start wondering.
TBN explanation would be nice too!!
#1701615 - 12/09/09 01:54 PM Re: Cheat sheet for newbies reading UOA's [Re: bloc]
addyguy Offline
Loc: Canada
You missed Antimony - used by some oils in their add-pack; I think it's an anti-oxidant?
2010 Kia Soul 2U - 2.0L I-4, auto, 85k miles.
QSGB 5W-20, NAPA select filter(?)
#1702278 - 12/09/09 10:17 PM Re: Cheat sheet for newbies reading UOA's [Re: addyguy]
White_Buffalo Offline
Loc: Sioux Falls, SD
Not that many labs test for Antimony. I have seen Amsoil's OAI testing and Polaris show it in there UOA reports. I thinks Schaeffer's uses Antimony as a high pressure additive.
2003 7.3L F250 Wildman tunes Van turbo, DIIC, AIS, swamps 175/146 inj
2000 Excursion - Rockin S built
2006 F-350, studded, EGR Delete, Wildman tunes
#1738405 - 01/10/10 09:42 PM Re: Cheat sheet for newbies reading UOA's [Re: White_Buffalo]
TucsonDon Offline
Loc: Arizona, USA
I think Boron is becoming part of the additive pack of some oils ... Rotella CJ-4 comes to mind as having increased the Boron.
2007 Goldwing + Rotella T 15W-40 CJ-4. It works; I'm happy.
Page 1 of 2 1 2 >
