I recently bleed the brakes in my 02 VW Jetta and noticed the brake pedal feels softer than before. The method I used was the 2 person method where one pumps the brakes and one opens the bleeder. I made sure to check the fluid level. The only thing I may have done wrong is the clear tubing was not snug on the bleeder. Its hard to get the tubing to stay, keeps popping off.
I wanted to know if there are one person methods without the use of pressure bleeder or vacuum. I have never done the gravity method where you open the bleeder and let it drip. Not sure if thats a good idea. Any suggestions welcome, thanks.
