My Neice has a 2000 Nissan Altima with a sticking drivers side front brake caliper which has worn down the pads on that side and blackened the aluminum wheel. The passenger side is fine!
I thought that I had fixed the issue with a new set of pads and cleaned and lubed everything very well. When pushing back the caliper piston so that I could install the new pads, the piston moved back very freely. Only the pads seemed to be frozen in their slots in the caliper mounting bracket. I took apart everything and cleaned the anti-rattle clips(the area where the pads slide in when installing). Lubed the area where the pads slide in, along with the slider pins and their cavity.
The drivers side wheel is black again and I noticed this when we arrived for Thanksgiving. I mentioned it to her an said that I would look at it again this weekend.
Is there something that I should be looking for when I take apart those brakes again. I will bleed the brakes on that side only which I did not do the first time. Any advise will be good advise.....Thanks
