- Joined
- Jun 2, 2003
- Messages
- 23,591
Sorry about dat.
My right front brake has been wearing the rotor a little uneven for a while. Nothing dramatic, but just enough to annoy me. at over 160k miles, these are the OEM brakes. The piston seals and boots have been replaced a few times during the past 11 years. Last time I changed the piston seals and boots was about 30 k miles ago. Back then I noticed that the guide pins showed slight signs of wear. Because one OEM guide pin costs almost $40 at the dealer, I decided to wait with replacement until I got a chance to pick the guide pins up for 1/3 the cost during a vacation in Germany.
Here are a few pictures that show my passenger side front brake, guide pin and outboard pad. As you can see, the rotor has almost reached its wear limit (slots are wear indicators), the pad is down, too, and both, rotor and pad show lightlly uneven wear.
The lube that I used on the guide pins has failed and has caused a sticky caliper, to which I attribute the uneven wear. Check out the dirty guide pin with lube remnants and the cleaned guide pins, which show wear and probably some corrosion.
Click the images for larger pictures.
Those don't look fly!
PS: Yes Ms Wan, those pads don't have shims.
