Originally Posted By: supton
Originally Posted By: madRiver
Originally Posted By: RISUPERCREWMAN
Sorry to hear about your loss but glad that your ok. The Crown Vic is one of the safest cars on the road period.
The car is not one of the safest because it kicked out the rear end and had no ability except driver reflex to place back into control. A modern stability control likely would have prevented this accident or made it easier to recover.
Except this was a modified car... Transmission was programmed to shift hard, and it happened to shift hard at the worst possible time.
Wild guess says a more modern transmission could be programmed to not shift hard on throttle lifts, and more importantly, the traction control work with transmission programming--but all bets are off on aftermarket. I also have to wonder if the OP even wants TC on this car--some cars are more fun in a, err, more primitive state.
If we really wanted to be bitog-obsessive, we'd point out how this would never happen in a manual transmission, or that if it did, then it'd be total user error... surprised that no one has suggested that as a fix yet.
It could've been programmed to shift softly on lift off. The way the computer decides what pressure to command, is a table with Throttle Position vs Speed. So when the shift line (MPH vs Throttle position) is crossed it looks at the pressure table for what to command.
This was simply something I hadn't thought of doing. If it mattered still, I would go back into the table and at high speed and low throttle say starting at like 20% and down, I would pull it back down to stock. Since the transmission valve body flows higher than stock I could even go under stock pressure. I would have to test it repeatedly to see how much I could pull.
ALSO, CAN WE NOT MAKE THIS ANOTHER FULL FRAME VS UNIT BODY THREAD PLEASE. IM TIRED OF HEARING ABOUT IT.
I love my full frame cars, and it did its job well in this case, but Im not married to it. Im hurt minimally and thats all I care about.
Also, I can tolerate manuals in the rural area I live in, but in the city I don't do any good with them.
