The ADBV has a spec/tolerance just like any other part. I believe these get tested under a pretty low back pressure with "hot" motor oil. Even then they are permitted to leak at a defined leakage rate (cc per hour, or cc per min). They can leak anywhere from 10-200cc/min from what I've read in some SAE J806 oil filter specs online. Do the math and you can see how much hot fluid can drain in that amount of time.
The ADBV can deform over time, too. We're talking about some basic molded NBR parts here -- not high-tech rocket science. Some of the premium filters might have silicone. If you look up the temp range of regular NBR, those ADBV parts will not hold their shape long after being blasted open with hot motor oil for a while. Silicone does much better (again, look at the eff temp range of the material).
Call Wix and see if they have a "spec" for ADBV leak.
