Originally Posted By: marine65
The Sentra needs new blades.
I always buy them at Walmart. The beam type runs from about $14 to $18 each.
I went on Rock Auto and bought a set of Bosch Clear Advantage beam blades for $15.79 for both blades including shipping.
Why buy at Walmart?
I also saw standard spark plugs for under $2.00.
Iridium plugs for $7.00.
I'm going to offer what is probably an unpopular opinion: BEAM WIPER BLADES SUCK ROCKS. I've tried a few different brands in several applications, and they all simply suck. The problem is inherent- the tips of the blade are only held against the windshield by the built-in "arch" of the beam, which lets the ends lift very easily. In contrast, the center of the blade is smashed hard against the windshield by the full force of the wiper arm spring, and so it scrubs too hard and won't re-orient properly when the wiper stroke reverses.
In contrast, traditional wiper blades have a series of articulated mechanical arches which take the strong pressure of the wiper arm and evenly distribute it to 6 or 8 points equally along the whole length of the blade, and the inherent stiffness of the blade only has to maintain pressure over 3-4 inches between the contact points instead of ~9-12 inches from the center of the blade all the way to the tip like a beam blade.
The downside of traditional blades is wind resistance and tendency to lift at high speed. So the best of both worlds are the hybrid blades that have articulated arches underneath, and an airfoil "shell" over the outside to prevent lift. Examples are RainX Fusion and Michelin Stealth.
