*Here's one for you : First oil change I did my own oil change on the Sonata using their OEM blue oil filter - next oil change I figured I would get an oil change at the dealer to get at least one oil change listed on their records . Later , I decided to change my oil again and much to my surprise I found exactly only half of the under cover bolt screws put back in (They were in a perfect pattern all the way around - just 50% less) . I went back to the dealer and politely called them on this and without saying a word they had the service center run me up 8 new under cover bolt screws . I assumed the Oil Tech decided to cut corners to save time by only replacing half of the under cover bolts ... Not the worse thing that could happen - it's the principle of the thing where you pay to have a job done right that is irritating !
