Originally Posted By: bepperb
The compression on OPE is generally low enough any gas will work. A lot of times people will recommend higher octane gas because the octane rating lowers while gas sits (which for OPE old gas is used often) and many times premium gas has no ethanol, both of which are good reasons to use it.
Really if you use fresh gas it probably doesn't matter.
I'm with bepperb on this one.
Citing RE: B&S Small engine repair and care (sp?) written in collaboration with Briggs and Stratton, citing that typical flat-head B&S engines run on approx. 7:1 compression ratio, and should be good to take on anything around 77octane or more.
In other words: 87octane (RON+MON divided by 2) should be more than sufficient to run your flat-heads.
OHV may require slightly higher than 87 (then again: system/manufacturer-dependent).
I'd run fresh, clean and doped (with fuel-stabiliser) 87 octane gasoline in my flathead at any given day than, say, run higher octane gasoline (but lost a bit of octane due to decomposition, etc.) citing the gummy deposits and carboning of the combustion chamber.
See my other posting RE: B&S 675 refresh and take a look at the combustion chamber deposits on a 7-season, owner-neglected head and carbon deposits....
Q.
