Amsoil's EaO. Maybe other companies will someday offer a clone.
Quote:
Actually the Motorcraft is melding of the PremiumPlus (filter medium) and the PureOne (silicone ADB).
We don't have an Amsoil source here, but all the others you mention I agree are good filters. Advance's AAP Totalgrip filter is decent too, as well as easy to install.Quote:
I'm happy with STP, Amsoil EaO and the Purolators. Wix/Napa Gold are good too!
Your Amsoil source is on this web site.Quote:
Quote:
If you can get the Motorcraft filter at Walmart, get it...otherwise, run the Supertech.
Quote:
Too bad some of the Amsoil EaO filters put the bypass valve on the wrong end. Amsoil's FL-1A "equivalent", the EaO15, appears to have the bypass on the closed end of the element. Purolator made the same lousy decision on many of the Pure1 filters.
In the case of the EaO15, what would be a top notch, first choice, filter for FL-1A applications becomes just another overpriced filter in my view. Because of the bypass valve location, I won't run a PL30001 or EaO15 when winter temperatures lead to frequent media bypassing.
Though I might run a Pure1 or EaO in the summer when it's warmer, much of the benefit of the costly EaO filter is lost when it's only used 6 months or so.
Quote:
I like Purolator, Ive used the Premium Plus and the PureOne. The Motorcraft is the same as a PureOne. I think they are a excellent filters and compared with the price and ease of which to obtain, they cant be beat. I feel the Amsoil/Mobil 1/KN arent worth the price unless you go over 10000 mile changes but then I still think the Purolator would show decent results even in extended conditions. My second choice would be Napa/Wix Ive used these in company vehicles that got oil testing and the resuts always came back excellent.
Quote:
Brian,
The Eao filter doesn't spend much of it's life in the bypass mode anyway. I don't see a problem using one on a Ford engine.
Quote:
Wix and Baldwin I like.
Quote:
There are two grades of Baldwin filters out there. The cheaper ones created a lot of start-up noise for me until the engine warmed. Tried three different applications on three different vehicles. Then I took the other five new Baldwins I purchased from that group of eight & tossed them in the garbage.
But yes... the "premium" Baldwin worked well for me on my Colorado 4X4. Will I buy the premiums again... no! It came with a ADBV-attached. My engine has a vertical filter mount & needs no ADBV.
